Replacement Battery charging cable.
Can somebody help me out here, the battery charging cable that came with the Spark drone... does anyone know where I can purchase a replacement or something similar....Thanks
Are you referring to the power cable that connects to the battery charging hub or a different cable?
You can use any Micro USB cable. If you need one, this Anker cable is a nice cable.
Just be aware that if you want to use the cable for data downloads/uploads as well, you will need a data cable as some cables only provide charging. Amazon have a good selection. Most mobile phone charging cables are ok too.
Any decent phone charging cable should work well.
bornzero2none
