Return to home when signal lost?
Sparkforlive
I have the spark now for 1 month and I love it! But live in the city and there's a lot of WiFi interference, so the signal lost often. I saw that when I lost the signal the spark just stays hovering or it just lands. But I don't want that, I want that it returns to home when signal lost. Only when the battery is 20% it returns to home.
Check out your TXT flight log to see if it explains what happened. You can upload and view it online here. If you'd like other people to review and comment on your flight log, then please post a link back here after you upload it.
From the DJI Spark manual:
I believe if you are in gesture mode or doing active tracking, the default setting will disable the RTH from going back to its home point and just make the Spark hover or land in current location. You can turn this setting off in the DJI Go App.
If your not using the gesture mode or active tracking, this would be an issue either in the firmware or Go App.
ayitsomar
