sdcar?
Gungor AYAR
Why can't I record on the sd card,it is 32gb sandisc and the bird is spark.Thank you.
When I slide sdcard option on the application ,a warning menu comes,then the sdcard option
Is the card inserted in the Spark correctly? Is it one of the supported card types?
i know on mine the sd has to be inserted upside down.. if you have the drone set on the ground you have to insert the sd car with the bottom side up .. atleast on mine
ayitsomar
