Spark and Remote Control connection trouble
1-st potential method:
1) turn on spark, press button for approx. 6 sec (you need to hear 2 beeps) unpress button and turn spark off
2) turn on spark second time and press button for approx. 9 sec (you need to hear 3 beeps) and trun spark off
3) turn on spark third time and press button for approx. 2 sec (you need to hear 1 beep) and try to connect RC.
You need connect your RC to the Saprk when red led on the RC stops blinking and start light solid red.
2-nd potential method:
Turn off Controller and Spark
Turn on Controller Reset Controller (long press for 9 second Power Button)
Turn Off Controller
Turn On Spark Long press on Battery button for two beeps (6 second)
Turn off Spark
Turn On Spark Long press on Battery button for three beeps (9 second)
Turn Off Spark
Turn On Spark Once Again press on Battery button for two beeps (6 second) Then (without turn off) press on Buttery button for 1 beep (3 cecond)
Turn on controller Press tre battons Red Pause + Fn + Right Custom button till you hear short beeps and green sparking light
one more method
1 Turn off Controller and Spark
2 Turn on Controller
3 Reset Controller (long press for 9 second Power Button)
4 Turn Off Controller
5 Turn On Spark
6 Long press on Battery button for two beeps (6 second)
7 Turn off Spark
8 Turn On Spark
9 Long press on Battery button for three beeps (9 second)
10 Turn Off Spark
11 Turn On Spark
12 Once Again press on Battery button for two beeps (6 second) then (without turn off) press on Buttery button for 1 beep (3 cecond)
13 Turn on controller
14 Press tre battons Red Pause + Fn + Right Custom button till you hear short beeps and green sparking light
15 It must connect
These 3 methods helps to connect spark and rc for two different people.
After reporting to DJI my inability to re-Pair the A/C and the R/C (after SPARK had flown OK , earlier) I only got the suggestion to send it back to DJI , "to assess the cause of the trouble"....
Very fortunately I came across this Post of yours and solved the problem using your First Method.
This is a terrific help and I am pretty sure many other Users would agree as it seems loosing the Pairing is
quite common.
For several days I had tried the 3 , 6 and 9 second resets but not in the sequence you suggest !
Again many thanks : you are a Brilliant Pilot
LynI816428
