Spark battery connector
DJIBILL
Hi does anyone know where i can get a spark battery connector or single terminals that will mate up with the connector terminals on the actual Spark.
…..or what the connector is called....terminals etc.
Reactions: Andre Levite
You can get a "spark battery connector" on eBay. Here is a close up of the terminal end with cable attached...
9936
that's not what i want. i want the BATTERY connector, not the spark drone connector, not what plugs into the battery
Are you talking about the USB Micro?
I'm pretty sure he's talking about the connector on the battery itself that mates with the connector on the spark; he's essentially looking for some way to plug an alternative device/battery/cable into the spark itself using the pin design found on the battery.
9945
I'm not sure this is something that will be easy to find ...
Reactions: CooperTowle
JeroldLabe
