Hi !
I was curious ;-)
I started with the Mavic Tx Teardown guide but then learned about the differences:
-1- dont remove the phone holder arms, different mechanics here...
-2- of couse no LCD but dont worry about buttons as they are better integrated in one solid element
-3- THINK of pulling two ribbon cables to the stick / button top part (closeup shows latch that has to be turned up in red circle)
All in all it was easy, scary parts were the first step (front board, beginning is always the hardest) AND popping the Antennae.
But it all worked out, just think of using a plastic pry tool and no metal.
This way i got it done scratchless and can put it together withou any damage (technical & optical).
I'll play aorund with differend ANtennae and/or Boosters soon...
You are of course allowed to repost my images (no rocket science involved) but please at least give "Ender" kudos, will you ? It DID cost some drips of sweat (that were unjustified in the end...)
Ender
Stuff:
I started out with this video, Kudos to Daniel:
Then i had the top removed AFTER pulling two ribbon cables by opening their lock:
Here is the full view after removing front & top, i guess the internal Antenna is connecting to the smartdevice (visible SSID) while the two front Antennae use hidden SSID or modified WiFi protocol to the spark (or ocusync at all ?!)
Removed the button board after prying away internal antenna (double sided tape only) and unlocking & pulling the ribbon cable:
removed battery after pulling power connector, UFL's visible, Yihaaaa:
removed Antenna, sortof naked remote now:
You also may want to shut up that beeper forever under the main PCB, i will if i decide to keep it.
Same as with mavic, ******* DJI's forcing beeps on us...
Greetings,
Ender
I was curious ;-)
Ender
Stuff:
Greetings,
Ender
