Start Routine (Check list)
Paul215
Germany
Hi guys,
I want to glue a small check list in my spark case to prevent failures and flyaways. I would like to hear if you have some important points to add or modifications on my list.
Restart mobile
Airplane-mode (friends too)
Turn off smartwatch
Unfold Spark props
Start Remote
Start spark
Connect OTG - cabel (or wifi)
Start Go4
Check Compass
Wait for strong GPS
Homepoint set??
Take off
Fly just upwards until 7m (precision landing)
Hover for around 30s
Have fun :)
Don't forget to take off all your clothes, and use some gloves. :)
I'm joking. It's a very good list.
I would only add, remove gimbal protection (I use it while spark is in its case).
Hi guys,
Restart mobile
Turn off smartwatch
Unfold Spark props
Start Remote
Start spark
Start Go4
Check Compass
Wait for strong GPS
Homepoint set??
Take off
Have fun :)
My checklist is almost identical.
I've added before takeoff:
Attach ND or polarising filter
Confirm SD card inserted
Turn up device Brightness 100%
Turn up device Volume 100%
Set manual WB (sunny/cloudy)
Set manual shutter speed
It all becomes reflexive with regular flying but easy to forget a step if it's been a while. Cheers!
Reactions: JREESY and Paul215
I put a list on the edges of my mini4.
The left hand and lower right side is a conversion chart for metric / U.S. units.
The top right is my preflight checklist.
Reactions: Paul215 and Mikej
Hey thanks for all the hints! I will add them to my list! Here is my check list 2.0:
Pre-Pre-flight :)
Check UAV Forecast (wind, KP)
SD-Card on board?
Battery loaded?
Spark Check:
SD-Card?
Remove Gimbal protection
Unfold props
Attach filters
Phone/tablet check:
Restart phone
Airplane mode
Check for other interference sources (smartwatch, friends mobile)
Brightness 100%
Volume 100%
Starting process:
Turn on remote, then spark
Connect everything
Check Compass
Wait for strong GPS
Homepoint set?
Take off
Go sparking :)
Maybe some will say the list is fussy :) Normally I remember the most of the thinks when I go flying. But last flight I was with some colleagues (was nervous) and made many mistakes. Wish I had a list at this moment...
Reactions: McCloudSpark
Great idea with the ipad! What is the reason for the conversion chart? Units in Go4 not changeable?
Hi guys,
Restart mobile
Turn off smartwatch
Unfold Spark props
Start Remote
Start spark
Start Go4
Check Compass
Wait for strong GPS
Homepoint set??
Take off
Have fun :)
I turn off bluetooth and wifi...........and airplane mode off....
and it works... is that proper and correct?
Some are, but not all, at the time I made the list.
I think some improvements have been made with past updates by showing the conversion in parentheses.
Great ideas and great list.
I must add the sunshade I bought a few days before, because here sun is very strong, and iPad has a limited brightness.
And as Andre said, don't forget to check UAV Forecast, before even leave for a flight.
Does anyone have used the "DJI pre flight checklist" app?
Reactions: Paul215
Great list!
It seems like a good habit to also make sure the battery is well latched and install the battery clip if you have one.
I also routinely inspect the props.
Reactions: Paul215
My phone is an Android device.... When I put it in airplane mode it automatically turns off everything including Bluetooth and wifi. Of course you need wifi on to connect your rc
Pre-Pre-flight :)
SD-Card on board?
Battery loaded?
Spark Check:
SD-Card?
Unfold props
Attach filters
Phone/tablet check:
Restart phone
Airplane mode
Brightness 100%
Volume 100%
Starting process:
Connect everything
Check Compass
Wait for strong GPS
Homepoint set?
Take off
Go sparking :)
Hi. I think you forgot one of the most important pre-check. That's altitude setting for RTH according to your PRESENT environment. I found myself in very scarry situation where standard 30m was not enough...
For almost all the rest the plane warns you, but not for this one...
Reactions: Paul215
Jep you are right! I will add it, too. Thank you!
Reactions: JREESY
We had great weather yesterday so I went flying. First time with new checklist and also tried precision landing for the first time. I startet from a helipad, go to 7m, hover 20s and then start flying. When my battery reached 40% I hit RTH. Sparky first went to RTH altitude and then came back. But in the beginning of landing it was around 2m aside the helipad. After reaching the VPS altitude sparky start to correct itself and landed perfekt in the inner circle of the pad.... Awesome!
It's great when things work as advertised :)
Reactions: Paul215
My RTH experiences have all been similar. I'm sure that I am pressing my luck by using it...
NoeFolk502
