Sunrise Hyperlapse - May 7, 2018
Thanks!
What you do is you line up on a triangle to what you want to fly.
For example here, I came down and around to the road about a block and 1/2 away.
Distance is one side of the triangle, the road (target) is another and then the direction traveled is the last side.
To do that travel use regular mode (not Sport), line up everything as seen with that start distance away from the target (important) and fly with the right stick in the upper right corner of the circle.
That produces the forward right motion and a little extra speed.
Run the clip through Filmora or an editor that can speed up the clip.
I think I did 6x for this one.
Then, just play around on those angles for other shots.
You will get the hang of it.
Best results:
Fly 1500 feet (460m) to the right or left of you and start.
That way you can capture 1500ft to you and keep going to capture 1500ft away from you.
You are in the middle.
Then try 10 - 20X and see what you got :D
bornzero2none
