Two Pilots, One Spark. How to Register?
Spark 317
Well known member with a Spark and a Mavic Air 2.
Indiana, USA
This topic came up the other day...
If one person in the household is a Part 107 pilot, and the other is not, can both fly the same drone?
I assume the drone would be registered as a Part 107 if going to make money.
I heard once you become a Part 107 pilot, you cease to be a hobbyist and have to abide by the FAA rules.
Do you need two drones and register them separately, OR register one drone twice, OR just stick with Part 107 registration and let the hobbyist fly it?
If the drone is registered as commercial, does the Remote Pilot in Command have to be present when the hobbyist flies it?
Yes.
That's not accurate. You need to decide whether you're going to fly as a hobbyist or commercially before each flight. Then, follow the appropriate rules throughout that flight.
You only need to attach one registration number to the drone. If the registration is associated to you, you will likely be held responsible no matter who is flying the drone.
No.
