Hi! I've been hearing a lot about connecting the controller directly to the phone instead of using WiFi. Is one better than the other? Is it that no WiFi is a more stable flying experience? Just wondering. Thanks!
You will not be able to gauge any lag if you are flying in a straight line. Fly out about 100m and then yaw (rotate the aircraft on its axis). If there is any lag, you can easily make out from the screen. It is very necessary to have zero or minimal lag when you want to use the drone for shooting videos. But if you can fly using VLOS all the time and intend to mostly take photos, you can live with the lag.I haven't witnessed much of a lag, but then again, I'm just getting used to looking at both the drone and screen. I can see where a lag may be of concern. Thanks for the info!
There are two connections we are dealing with.
1. Connection between RC and Aircraft
2. Connection between RC and Phone/Tablet
The first one is a WiFi connection and we can do nothing about it. The second one can either be a WiFi connection or a wired connection (OTG). Many users have found that when they use a WiFi connection between RC and aircraft, there is a noticeable lag in the live video feed on the DJIGo4 app, probably due to the two WiFi connections interfering with each other or with other WiFi devices nearby. An OTG cable eliminates such interference and gives a much stable video feed. However, many users have also reported that they have absolutely no problem with WiFi connection and they rather find a dangling cable between the RC and phone quite a hassle. I belong to that category of users who find it impossible to fly without an OTG cable because the live feed is terrible on WiFi. A lot actually depends on the environment you are flying in and the device you are using. If you ask me, I would highly recommend an OTG cable because theoretically it is a more reliable way of connection and it is not very expensive too.
Try switching the cable around..... If you connect the wrong end to your phone or rc it will never connect. Try this and let us know what happensI have a quick question: What am I doing wrong? I just tried using the OTG cable that came from DJI with my new Spark to connect my Galaxy S8 phone . I put the phone on airplane mode , but it wouldn't connect to the RC. After a minute I removed the OTG cable and turned off airplane mode and the phone connected right away wirelessly . But there is a lag I'd like to avoid using the cable . What am I doing wrong?
As I know, an otg cable comes with spark - goggles combo, only.I have a quick question: What am I doing wrong? I just tried using the OTG cable that came from DJI with my new Spark to connect my Galaxy S8 phone . I put the phone on airplane mode , but it wouldn't connect to the RC. After a minute I removed the OTG cable and turned off airplane mode and the phone connected right away wirelessly . But there is a lag I'd like to avoid using the cable . What am I doing wrong?
I ordered mine from Amazon....I have a Android device so mine took type c.... Cost 8 bucks. Just search on Amazon ( OTG CABLE FOR DJI SPARK )As I know, an otg cable comes with spark - goggles combo, only.
Otg cable is a special cable. Normal cable for data and charging will not work.
Yes mine is the same way but I have seen on here people were having this problem and switching the cable around solved the problemHe can't hook it up the wrong way. The Galaxy S8 is USB-C.
Well, not exactly.The only difference between a standard USB cable and and an On The Go USB cable is the standard A plug is replaced with a MICRO B or C type plug or Lightning. The idea of OTG cables is to allow the connection of 2 USB devices.
The Pin Outs are all Standard. Hence the name Universal Serial Bus.all are cross capable for 5 volts and data and more.
