Video Feed Issues
Noe Molina
I am having a hard time keeping a video feed while flying my Spark. It often says Weak Image Transmission Signal or Interference. I have tested my flight in a wide open cotton field with nothing around and am still getting these issues. Any thoughts?
Notice in the first picture the Red icon on the top right. Can someone explain that to me?
I believe the issue is because of my WIFI setting. It currently looks like this (2nd photo). Should it be on Auto? does someone mind explaining that to me as well?
OTG cable or no? By the looks of your first screen capture. Your wifi signal is strong, but the video transmission back to your device is weak.
As far as your wifi settings, personally I feel that one should only change to manual if having problems with their wifi strength. The Spark will normally choose the very best band to use.
Reactions: suprPHREAK
The red one is the obstacle avoidance letting you know it's OFF.
Turn it ON and it should go back to normal.
bashirul
