Watch your Props!
Excesstext
I’ve had a couple of roughing landings where the Spark has fallen off the landing target (table/mailbox etc) as the motors have been shutting down so no damage to the Prop blades.
However today after a couple of flights over the ocean I was doing a quick prop check and realised I’d broken a mounting tab.
Yes I’ve probably put about 5km off distance over ocean like this, and to say I’m feeling lucky...
It’s probably worth taking the props off every few flights and checking the robustness of the mounts just to be sure!
Kylie
Lucky it was still able to come back to you could have been in the middle of the ocean if it gave up ;)
Excesstext
Tell me about it. I was thinking when it started on the last couple of flights it was a bit wobbly!
I was flying out of the 4th floor balcony of my hotel at the time and there was epic turbulence from the wind around the building.
AirCam
Florida
Good thread. After reading this, I retired my original 150+ flight props today.
Excesstext
That might be a good idea? I’ve done about 35 flights covering about 30km so I wouldn’t expect any stress damage except for bumping in the bag (the FlyMore bag) and the couple of rough landings.
I guess I had assumed like my other quads the prop blades were the weak point but I think in this case it’s the locking tabs.
Sparkandfly
Treat your drone as if it's a real aircraft and do a pre flight check every time before a flight.
Ray215
