Yeah thanks that is what i ended up getting and what a difference it has made to my flight distance without interruptions,, wouldn't fly without it now. Cheers for your info.Micro USB to Micro USB.
Hey there. Well i got one now and the difference in range and uninterrupted video feed is outstanding, i use to get bad video feed at about 600m. Flying now in the same spot i went to 1.5 km and not even a small glitch. I'll never fly without on otg again.You don't need one. Read the posts on this subject.
Otg cable connects smartphone to controller.Hey there. Well i got one now and the difference in range and uninterrupted video feed is outstanding, i use to get bad video feed at about 600m. Flying now in the same spot i went to 1.5 km and not even a small glitch. I'll never fly without on otg again.
The range i am taking about is the video signal. Now the otg is connected there had been no video signal drop as the wifi now can concentrate 100% on communication between the spark and controller by not adding another wifi between controller and phone. The difference for me has been outstanding.Otg cable connects smartphone to controller.
How can it affect range? (Connection between controller and spark).
There are different transmitters, for these connections.The range i am taking about is the video signal. Now the otg is connected there had been no video signal drop as the wifi now can concentrate 100% on communication between the spark and controller by not adding another wifi between controller and phone. The difference for me has been outstanding.
well i can only go by what has happened. I have never had a good video transmission range until now so it must be doing something.There are different transmitters, for these connections.
And the most important is, they are in different frequencies/bands, so they don't interfere.
Controller is always concentrated 100% on each of these two separate connections.
The factors that can affect range, are the signal strength (transmission mode), and interference in the area.
Lost video feed doesn't trigger RTH. Lost connection between drone and controller triggers it (your drone will return, if it's not controllable for a few seconds).Ummm.... Maybe the video feed to the phone? The spark will still be controllable with the remote but you'll lose video feed which triggers RTH. I thought all spark owners knew this. An otg cable is definitely recommended.
You can fly your spark without even a device connected to your controller (no video feed at all).
Lol!Stop arguing. An otg makes a huge difference. Please don't comment until you've tried it yourself
Rth is not related to lost video, but to lost connection between drone and controller. Of course, if you lose THIS connection, video feed is lost too. But if you lose video because of another reason (crashed app, bad cable, disconnection between controller and phone, etc) rth will NOT be initiated.Yes. Within a certain range. RTH is triggered when you lose video if you're past a certain distance
