Yaw to the right when I climb in sports mode.
Gavieboydgi
Has anyone ever had this problem it's really weird I've calibrated everything it's like it's something to do with the compass. I have a video of it doing it which I will upload later.
It flicks to the right when I climb in sports mode.
Sounds like a prop issue - exchange like props and try again. If it's a prop issue the birds CPU will take a few milliseconds to respond and will then make adjustments to the motor speed. Either that or the CPU is sending 'sport mode' commands to the ESC in series not in parallel, so that the drive is not reconfigured simultaneously. Does it occur when accelerating AND changing into S mode? What happens if you switch to S mode while hovering?
When I just hover in sports mode it's fine. It's when I'm pressing forward and rising at the same time it does it.
