Adjust Roll Gimbal is ok in -4...
ArielWWE
After my drone crashed because the battery was wrong, his gimbal was twisted on the horizon. enter a configuration and when I place it in -4 everything works ok! but I want it to be like before it looked good at zero. I already tried to re-establish factory values, clean the gimbal by blowing air, calibrate the IMU, calibrate compass I only have to install an old firmware but I doubt it will be solved. How can I repair the cardan? I leave some photos.
Reactions: Andre Levite
If it shows a level horizon all the time I'd just be grateful it survived the crash and is working fine.
That's what the gimbal tilt adjustment is for.
Mine was tilted from the factory and I did that adjustment over a year ago on day one. Never needed to touch it again.
Fly safe!
Fly safe!
Hello I inform you that DJI says that the adjustment should be between -1.5 or +1.5 but not in -4 as mine is! anyway I solved it but with a third-party application I leave link in case someone sees this and wants to solve the problem:
Yeh. I don't remember the number value of the adjustment mine required. Once I got it level it has stayed perfect for over a year.
Glad you got yours adjusted to your liking after the crash :)
Thank you men!
yes i want return the calibration to zero o a value almost zero
thnks for response
good Flys!
