Attaching info to Spark
BradmanOH
Cincinnati
Any advice on how to identify my Spark?
I put my phone number on the top surface along with the FAA registration number using a sharpie, but it doesn't seem to be well adhered. It has smudged a bit already.
I created a label with my Dynamo labeler but it doesn't want to stick.
The surface is kind of slippery and has a rough texture.
I wrote my phone number on the battery compartment vertical surface, doesn't seem to be as textured.
Thanks,
BradmanOH
Put your information on the SD card as a text file should you lose the Spark.
The Spark is lost with no way to get home should someone find it later and the stickers have worn out. :)
I went to Wal-Mart and bought http://www.walmart.com/ip/Avery-Easy-Peel-Address-Labels-1-x-2-5-8-300-Count/22133728?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227015993736&wl0=&wl1=g&wl2=c&wl3=52396656431&wl4=pla-83960579111&wl5=9029830&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=22133728&wl13=&veh=sem and printed 6 with my name, FAA# and Phone # and adhered to same place as above post and to each other individual pc of the set. I also printed Numbers 1 through 3 so I could label my batteries and rotate them
I did this, but then when I was having recording issues, I re-formatted the SD card, so it is no longer on there.
That's one of the drawbacks of formatting the card in the Spark.
I dump my files in the PC, format the card in the PC, then reinstall the text file.
