Battery problem
biswasg
I had bought the DJI Spark Fly More Combo (Alpine White) in November 2017. After a little use, I did not use it for almost 2 years. Recently, when I tried to use the Spark, the batteries did not seem to be charging. I tried charging through the 3 battery platform as well as directly in the Spark. Only the first two green lights blink. Even after charging them overnight, the batteries remain dead.
Anything else I should do?
Reactions: Homicide38
Sorry about your batteries.
They may have sat too long and may not work again.
They are supposed to have a minimal charge at all times through battery care by charging them up to 50-75% and let them sit for a month and repeat the process.
A minimum charge of 10% is required to maintain the intelligence of the battery and once that is depleted, so is the battery.
Batteries are still available for purchase on line.
B and H Photo had some for $49 but are currently out, but more are on the way.
Amazon has them for $63.
shop around and good luck.
Welcome to the Forum. :cool:
Ah, I am not sure the battery availability in Switzerland. I remember seeing a video where a person rejuvenated some completely dead cordless drill batteries by giving the individual cells power from a charged cell for a very short time. This gave them enough power for the charge controller circuit to allow the battery to be charged normally.
There are also people who connect a standard Lipo battery to the Spark as well... Try googling
I'm having the same problem. I've been Googling for the past 3 days and haven't really found any solution other than to buy new batteries. I was able to open up one of my batteries and manually charge it with a bench-top power supply to 12.6V (4.2V/cell) @ 0.125A (low current to reduce risk of fire/explosion). The battery is holding a charge which is good indication the cells are not totally ruined from over-discharging (albeit, likely has degraded capacity). Despite returning the pack to a stable state, the charging hub and USB air craft charger refuse to charge the battery. When inserted in the air craft, I can press once, press and hold for 2 seconds to turn the battery on, but the air craft will not power up. I did some more digging and discovered the battery management IC is a Texas Instruments part number (BQ9003). I couldn't find a datasheet anywhere for this IC. I believe the battery management IC sets a persistent error flag when over-discharged which renders the battery useless. To reset this flag would require an SMBus adapter and software, similar to what is shown in the two videos linked below. Cheapest I could find a TI EV2300 HPA002 pod was for $100 on eBay ($120 for two new battery packs on Amazon...).
Battery Mavic Air Repair (Remove Permanent Fail):
Battery Phantom 4 Repair (BQ30Z55) - Romanian Lang:
(This one is in Romanian, but you can auto-translate captions to English)
Here is a good summary of the issue:
Disclaimer: I do NOT recommend anyone attempt to manually recharge an over-discharged LiPo battery without first knowing what you are doing. There is a real risk of fire and/or explosion so precautions must be taken.
Wow. That looks like more work than I would be willing to do. That will give me a motivation to make sure maintain my batteries correctly while storing them.
Thanks for posting!
elyte
