Battery strap
garymk1966
After seeing posts about the after market battery strap and the fact you can't have it and the prop guards fitted at the same time,prompted me to find a solution.
And what I have done is use a Dremel type tool to trim the sides of the battery strap and now the prop guards can be fitted at the same time.IMG_20181003_183834.jpgIMG_20181003_183757.jpgIMG_20181003_183749.jpg
I have an aftermarket prop guard and it works with this battery strap without issue. This battery guard without the modifications as you performed I confirm it won't fit with the DJI prop guards. Screenshot_20181003-144648.jpg
Reactions: Icemanwbs
I was going to that with mine but was concerned about weakening the structural integrity of the strap to the point of bending or breaking but it looks like it works.:)
I've been using the rubber O ring trick.
Thanks for posting.
JestineDaw
