Broken Arm on Spark!
Although JB Weld is a good short time fix in a pinch, it may not be the proper repair in the long run.
I have watched YouTube videos and built confidence in my ability to repair the appliances around the house that I never would have tried on my own.
The Spark was put together which means it can come apart.
The Spark tear down and rebuild videos I've seen look to be very informative, as long as you follow the steps.
Watch different videos and take notes.
One may have an easier way than the other when reaching a goal.
It looks like a soldering gun, a torx driver set, and patience may be all that's needed.
Practice soldering with scrap wire before working on the Spark.
If you don't feel confident yourself, there are repair shops available that will do it for you.
Here is DJI's site.
one other thing , take photos with your camera a lot of photos every step of the way . i did a drone frame rebuild a couple of years ago the photos maid the rebuild easy . now the soldering is not hard but if you take your time it will be ok .
DanielaLau
