Can't make OTG connection.
Steve Kennedy
Put phone in airplane mode and still the phone won't see the wired connection. The phone is an Alcatel U50 running Android 7. Any insights?
U50 seems to support OTG connection. perhaps try to connect the cable conversely..worked for some people (in wrong direction the phone was charging only but didn't connect to RC).
if no luck, try different OTG cable.
Not all cables are created equally. You may have to try several before you find one that works. I've had best luck with thickest, shortest, newest ones. Especially good are cables originally packaged with a name brand accessory.
The order in which you connect the terminals (phone vs. RC first) can also be the difference between success and failure.
Good luck
try this
OPEN PHONE TURN WI-FI &BLUE TOOTH OFF​
PUT PHONE IN AIRPLANE MODE​
START UP SPARK, START RC WAITE FOR GREEN LED​
OPEN DJI GO 4 APP, PLUG IN OTG CABLE​
DJI GO 4 APP READS CONNECTED​
try this
Exactly.
ChunGreenh
