Changing Wifi
OC Drone
I arrived in Spain, and my video signal is lost at a short distance (with OTG).
I believen the WiFi needs changing.
When I go custom, it only shows the 5.8G, but I believe I need the 2.4G. How do I fix this? I've done a reset & reinstall of app. Can someone supply detailed wealth through?
The short answer is to not use OTG when changing band or channel.
Connect your device to RC via WIFI, start up drone and have everything connected.
Change whatever, wait for success..
Then power down everything..
Reconnect like normal with OTG..
Now it should be running on your new channel/band.
Fly safe :)
Reactions: jofaragon
Fly safe :)
Connected everything without OTG, but still doesn't show 2.4G, only 5.8G.
Without the OTG and 5.8G, I will have better results?
I had the same problem so I sent to dji. I justt received an email saying they replaced main board.
Heck
