Weak image trasmission signal with wifi and no signal with OTG issues
fjadue
When i use wifi connection with the RC and flying at a distance near 100m i start having weak image trasmission signal and when using OTG near 100m distance i have No Signal and lost the image if the drone. Im using galaxy s7. Do anyone know how to fix this???
Sent from my SM-G930F using SparkPilots Spark Forum mobile app
Did you disabled bluetooth ? It can have an influence even if you use cable connection.
Second, are you really sure that your antennas are correctly orientated. You should double check in the manual, they should not point to the Spark but be perpendicular to the direction of the Spark.
Reactions: fjadue
Wifi is cheap for manufacturers to implement and test in labs.
But for users, the performance is totally circumstantial, from perfect to very poor.
1StCoastMavic4
