Close call with a Weir
Leskent
My eyesight must be worse than I thought on screen and LOS it looked like I was maybe 6ft away, What a scare when I checked the video from SD card back home
I personally liked the video and the way you constructed it. I would however suggest you might also approach the subject from behind showing how the falls deposit the water. I like the way you ended it by taking the Drone high. I also would suggest not duplicating the original. Still you get an “A” from me for whatever that is worth. Since you might be relatively new, others should do what you have done. Congrats on getting so close to the falls, better you than me though.
Cheers...
Great video of waterfall and yes you did come close
Cheers...
Thanks for your positive comments, but I must point out there is no "duplicate" footage I shot on 2 separate batteries the view is similar because it was the only vantage point I could access to take off and land
1StCoastMavic4
