Decrypt any DJI flight log with Flight Reader
A new version of Flight Reader is available. Release 1.6.3 includes the following changes:
  • Added support for processing Mini 4K flight logs.
  • When flight logs are synced using the “File” → “Sync Flight Logs” menu item at the top of the main Flight Reader window, TXT flight logs found on any Android devices (phone/tablet/DJI RC) connected to your computer will be automatically imported into Flight Reader. If Flight Reader is started after connecting an Android device, the TXT flight logs will be synced automatically when Flight Reader starts.
    Note: Make sure your Android device is connected to your computer using a USB cable that supports data transfers (some USB cables are for charging only). For Android phones/tablets, choose the “File Transfer” USB mode when prompted after connecting the USB cable. For DJI RCs (with a screen), check that you have the latest firmware installed if you have any trouble transferring flight logs.
  • New settings have been added in the “KML” section of the Flight Reader Options window to set the width, color, and transparency of the ground line in the generated KML files.
  • Resolved an issue that was causing some flight logs to fail to process when flight log fields contained an empty value.
See the release notes for a complete list of changes.
A new version of Flight Reader is available. Release 1.6.6 includes the following changes:
  • Resolved an issue that was sometimes causing the main Flight Reader window status to get stuck at “Processing flight logs” while attempting to sync flight logs.
A new version of Flight Reader is available. Release 1.6.9 includes the following changes:
  • Added support for processing Neo flight logs.
  • When using the “File” → “Sync Flight Logs” feature to sync flight logs from a local Android device (as documented here), flight logs will also be synced from Litchi if installed.
  • Removed the repeated “Auto returning to home” placemarks from the map and KML while the aircraft is returning home.
  • When adding new fields in the “Logs/Reports” section of the Flight Reader Options window, the new field is added below (instead of above) the field selected in the “Selected Fields” list.
  • The “Sync History” menu item is only displayed in the “File” menu when history data is available.
  • Resolved issue causing Flight Reader to crash when attempting to open an aircraft log while the associated CSV file was open in Excel or other CSV reader that locks the CSV file upon opening it.
A new version of Flight Reader is available. Release 1.6.11 includes the following changes:
  • Added Flight Log Transfer Service to allow flight logs to be transferred to Flight Reader over a local network from a mobile web browser on an Apple or Android mobile device.
  • SRT files can be converted to KML files by dragging and dropping them onto the main Flight Reader window.
  • Tips and warning messages that repeat in consecutive rows are now displayed once and not shown again until logged again later in the flight.
  • When exporting files from Flight Reader, files in the export folder location are no longer deleted before exporting the selected files.
  • Some flight logs were populating the aircraft component serial number fields with unreadable characters.
  • Some battery fields were populated with a "0" when no data was available in the flight log.
A new version of Flight Reader is available. Release 1.6.14 includes the following changes:
  • Added Charts to generate line charts from flight data in the aircraft CSV.
  • Discovered the best local IP address for the Service Location displayed in the Flight Log Transfer service window.
  • Resolved an issue that prevented the aircraft CSV from auto loading into CsvView when the file path contained spaces.
  • Resolved an issue causing the “OSD.flyTime” field to be set to 0 when the last line of the flight log was still saving while the drone powered off.
  • Resolved an issue causing the “APP.tip” and “APP.warning” field values to spill into other columns of the Aircraft CSV when Windows uses “;” as the CSV separator.
A new version of Flight Reader is available. Release 1.6.17 includes the following changes:
  • Added support for processing Air 3S flight logs.
  • Added support for processing Specta Mini flight logs.
  • Added ability to process GUTMA flight logs.
  • Removed “sep=” line from the top of generated CSV files.
  • Allowed “&” to be included in the name when saving a favorite chart.
  • Resolved several crashes that can occur after removing fields from the Aircraft Log in the Flight Reader Options.
A new version of Flight Reader is available. Release 1.6.21 includes the following changes:
  • Added a new "OSD.yaw [unwrapped]" field for easier visualization of aircraft yaw changes. This field shows the aircraft's cumulative rotation angle, with positive values indicating clockwise turns and negative values indicating counterclockwise turns, reflecting total degrees turned in either direction.
  • Added an optional "Battery Times Charged" column to the Flight Reader main window. To add this column, right click the column headers and select "Customize Columns".
  • Updated the "Flight Date" dropdown at the top of the Flight Reader main window to include the count of flights displayed in the main window.
  • Enhanced performance and precision of the fly time line drawn on charts when moving the mouse pointer over graphed lines.
  • Removed the Byte Order Mark (BOM) from the first line of CSV files generated by Flight Reader. This change ensures compatibility with CsvView and other CSV viewers that cannot process CSV files with BOMs.
  • Remember the last selected column sort order in the Flight Reader main window and improved performance when loading or reloading flights.
A new version of Flight Reader is available. Release 1.6.24 includes the following changes:
  • Added support for processing Anzu drone flight logs.
  • The "OSD.mileage [ft]" and "OSD.mileage [m]" fields now use speed data to calculate the distance traveled when GPS location data is unavailable.
  • Updated existing DJI remote controller syncing functionality to check for flight logs located in the "dji.pilot.pad" and "com.dji.industry.pilot" directories.
  • Resolved several issues where images and controls appeared smaller than expected on displays with Windows scaling set above 100%.
A new version of Flight Reader is available. Release 1.7.1 includes the following changes:
  • Resolved an issue that could cause a crash when copying data to the clipboard in the Aircraft or Battery Log window.
  • Resolved flight log decryption issues that sometimes caused photo capture points to be recorded incorrectly.
  • Resolved an issue that prevented the main Flight Reader window from appearing on top of all other windows when starting Flight Reader.
A new version of Flight Reader is available. Release 1.7.2 includes the following changes:
  • Added support for processing Flip flight logs.
  • Added support for processing Matrice 3TD flight logs.
  • Improved the message extraction logic to ensure more consistent formatting of tips and warning messages.
A new version of Flight Reader is available. Release 1.7.5 includes the following changes:
  • Added support for processing Matrice 4T flight logs.
  • When processing a flight log, a snapshot of the flight path is automatically generated and displayed in the "Photos" column of the flight list in the main Flight Reader window (view demo).
  • The RC.aileron, RC.elevator, RC.rudder, and RC.throttle values are now grouped together on the same chart axis for enhanced readability.
  • Resolved a crash that occurred when loading the Aircraft History while the "Aircraft" column in the flight list of the main Flight Reader window was hidden.
A new version of Flight Reader is available. Release 1.7.7 includes the following changes:
  • Added support for processing Matrice 4E flight logs.
  • The “Home point updated” message is now suppressed when the home point shifts less than a few inches. The generated aircraft log will still record these minor adjustments for models affected by what appears to be a bug in the DJI flight log creation process. However, since the change in home point location is minor, it’s no longer included in the “APP.tip” field.
A new version of Flight Reader is available. Release 1.7.8 includes the following changes:
  • For drone models with dual batteries, the serial numbers for both batteries are now stored in the SERIAL.battery and SERIAL.battery2 fields.
  • Serial numbers can be found in the RECOVER.*, DETAILS.*, and SERIAL.* fields depending on where they are extracted from flight logs. All serial numbers have been combined together and stored in the SERIAL.* fields. When referencing serial numbers, use the SERIAL.* fields as they now provide the most complete data.
  • Added more size options to the Log Viewer Map Size setting in the General section of the Flight Reader Options window, allowing greater customization of the Google Map height in the Map log viewer.
  • Flight path markers on the Google Map are now only displayed when the home point is initially set or manually reset by the pilot. While small automatic home point adjustments, such as those made by drone models like the Air 3S, are still logged in the APP.tip field with "Home Point Updated" messages, they will no longer appear as markers on the Google map to reduce visual clutter.
A new version of Flight Reader is available. Release 1.7.9 includes the following changes:
  • Resolved an issue that prevented photo and video data from being extracted from Mini 2 flight logs.
  • When opening the map view for a processed flight log, the map will use the current “Log viewer map size” setting from the “General” section of the Flight Reader Options window instead of the size that was selected when the flight log was processed.
A new version of Flight Reader is available. Release 1.7.12 includes the following changes:
  • Added a new OSD.tiltInclination field to display the drone’s overall tilt angle, showing how much it leans relative to a level horizon during flight.
  • Add new fields DETAILS.droneManufacturer, DETAILS.droneModel, and DETAILS.droneManufacturerModel allowing the drone’s manufacturer and model names to be shown separately or combined.
  • C1 and C2 button presses from all DJI RC remote controllers are now captured in the RC.custom1Depressed and RC.custom2Depressed fields.
  • Resolved an issue introduced in Flight Reader version 1.7.9 where the CAMERA.isVideo field could incorrectly remain set to True after video recording stopped.
A new version of Flight Reader is available. Release 1.7.15 includes the following changes:
  • Added a new DETAILS.sha256Hash field. This SHA-256 hash uniquely identifies each flight log file based on its content.
  • Added support for syncing TXT flight logs from Android devices using Litchi Pilot.
  • The Mavic 3 Multispectral model name now correctly displays as “Mavic 3 Multispectral” instead of “Mavic 3”.
A new version of Flight Reader is available. Release 1.7.18 includes the following changes:
  • Added support for syncing TXT flight logs from DJI RC remote controllers or Android devices using Dronelink.
stathis13
