Decrypt any DJI flight log with Flight Reader
A new version of Flight Reader is available. Release 1.8.34 includes the following changes:
  • Added support for processing Agras T100 flight logs.
  • Added support for processing Lito 1 flight logs.
  • Improved the exterior boundary of the Flight Area KML to more closely follow the outer edge of the flight path.
See the release notes for a complete list of changes.
A new version of Flight Reader is available. Release 1.8.37 includes the following changes:
  • Added support for custom aircraft/battery reports and usage reports in the Logs/Reports section of the Flight Reader Options window. All added custom reports can be accessed from the Reports menu by right-clicking any flight in the main Flight Reader window.
  • Improved flight log processing performance by reducing the time required to generate the KML files that are created when a flight log is processed.
  • Fixed an issue where importing the same flight log using different filenames could cause duplicate flights to appear in the main flight list and reports.
DelmarChac
