I'm sure a lot of people will really like the dynamic home point feature. It looks like we'll have to wait until the new Spark firmware update to use it though (per this thread). Let's hope that DJI employee is not correct in saying the dynamic home point feature is only available when using those few select flight modes.
The dynamic home point feature will most likely only auto reset the home point to the remote controller's current location (assuming you're using a mobile device with a GPS receiver).Why would you want the craft's position to be auto-set to its position outside of active tracking?
It would be useful in any scenario where the pilot moves away from the last marked home point. People commonly have a need for something like this when flying from a moving boat.As "Malakai_UK" writes in the thread you linked, this auto RTH setting sounds like it would be only really needed/useful for active tracking without an RC, i.e. currently max limit in gesture mode is 15 meters and in smartphone mode 100 meters.
That's the only way DJI has ever implemented the dynamic home point feature in the past. Let's hope they allow it to be dynamically reset to either the aircraft's current location or the mobile device's current location.I doubt they would do any automatic setting based on the GPS position of the smartphone/tablet
Manually resetting the home point every time a continuously moving boat has moved is quite the hassleAs for piloting from a boat (or skiiing/biking/driving) yes it could be convenient of course but you can already reset the home position manually
The drone fly's with a distance limit set with the home point as the center. so if you "rode your bike" outside of this circle the drone would stop at the virtual wall.Couldn't you that before ? Or are you saying you'll just connect the RC, start Gesture Mode tracking and be able to take control with the RC if something happens ?
Maybe not related, but after the software update I lost my video connection to my Spark. Right now my Spark is saying to contact DJI for service. I have only flown my Spark maybe a dozen times and never had so much as a small bump to have caused any problem. Curious if anyone else might be experiencing the same?Has anyone tried it? Surprised that there are no threads on this yet?
Cheers
M
Cheers
M
Cheers
M
