- Join
- Oct 22, 2018
- Messages
- 13
- Age
- 55
What is the best size, brand, etc, screen for the the UAV.
Something not so big it's cumbersome, works best inn the sun.
Best possible charge sustainability, best potential storage capability,
Has the most adaptability with largest range of consumer aftermarket upgrades.
I'm currently using a Samsung Tab A which is not the best size as it's to large for compact requirements. The Samsung s9 is a super phone,
But all adaptor USB C Cables do not fit at all if you use a screen protector. I'm constantly have to remove phone protection to use with (Joystick Pad) that comes with the Flymore setup.
The other flaw I noticed with the controller is the fact the Antenna mounts are not adaptable.
I installed adaptor lugs before It was ever flow. I Can now screw on any size or style antenna I want with the idea of maximum potential with regards to RF gain.
Which is the best spectrum transmission antenna for the Spark?
I noticed performance between 8dbi and 7 there isn't much difference.
Square surface to verticle surface antenna design.
I'm sure there's a maximum potential Non-amplified and power amplified antenna . Just not sure which is the best.
And as for envelope package antenna amplification. I'm also a Ham Operator with a General License.
Thanks.
Randall J Hurd.
Thanks.
Randall J Hurd.
