downward sensor knocked out by low cloud...
BrianP
just sharing my experiences from flying yesterday...
# I was at a landmark, 400 feet above sea level
# I was at a height of 100 feet
# the downward sensor failed and I was messaged to land asap
# I pressed 'land' and prepared for a palm landing as normal
# the Spark did not slow down as it landed on my palm
# it was quite a fast landing
so... beware of landing after a downward sensor failure, a ground landing could end with a damaged gimbal!
# I also had display drop outs due to the low clouds...
# I flew again, shortly after, at a lower height above sea level and everything was back to normal, no downward sensor errors appeared and it palm landed as normal.
Hope this helps someone about to chance a flight in low cloud.
This is a know "feature" of DJI drones and clouds or fog\mist. On the spark you can't turn off the VPS system so your lucky to get yours back in 1 piece.
I believe the Spark manual specifically says not to fly into clouds or fog. There was a recent YouTube posted where a guy got stuck above the clouds because vps thought the cloud was th ground and refused to descend.
Don’t do it! :-)
Reactions: Lastrexking
qasimdhool
