FAA identification
lowoctane
Need a place to buy letters/numbers for my Spark. Thx in advance!
I sell inexpensive FAA labels here.
Reactions: lowoctane
Ok. I envisioned the number emblazoned across the fuselage!
A Sharpie marker will work as well.
You don't even have to write on the exterior of the drone if you want to keep it clean.
Inside the battery compartment will suffice per the FAA.
I've used de-natured alcohol to remove sharpie pen marks on stuff before. Might work...
My only problem with that is if you ever sell it you have to remove it.
I purchased a skin from decal girl.com and had them put my id on the top body skin. It looks real professional. You can put the id on the battery skin, the prop skins, anywhere you want. Cost $21 for a custom skin, many choices of colors. If you take them off, they leave no residue. Ron
Ordered the 1/8" decals. Once I get them, I'll post up some pictures...
Small font label maker - attached on top all the way back. Looks like part of the drone.
Heck
