Ok. I envisioned the number emblazoned across the fuselage!I just used my label maker to make a small label with my FAA number and phone number.
My only problem with that is if you ever sell it you have to remove it.A Sharpie marker will work as well.
You don't even have to write on the exterior of the drone if you want to keep it clean.
Inside the battery compartment will suffice per the FAA.
Little unknown cool trick. Write over any Sharpie writing with a dry-erase marker, wait a minute and you'll be able to wipe it off dry with just a paper towel.My only problem with that is if you ever sell it you have to remove it.
Huh! Have some 1/8" backless decals coming...I have a vinyl plotter if anyone needs my service.
You can put the id on the battery skin, the prop skins, anywhere you want.
You don't want to attach anything to the props. It will affect the balance.Prop skins?
Right, that was my pointYou don't want to attach anything to the props. It will affect the balance.
