Inverter
As mentioned in the previous post, the charger is capable of generating ~50 watts, so factoring in overhead/efficiency I think you'd be quite safe with a 100W inverter. I doubt you'll find an off-the-shelf pure sine wave model with a rating much lower than that.
If your battery has a 90 hour amp rating, you should be able to run the 400 watt continuous load for approximately 2 hours. The higher the amp hour rating on your battery, the longer the battery will last.
ChunGreenh
