- Join
- Aug 8, 2017
- Messages
- 19
- Age
- 47
How far is it drifting? How often does that happen?Is it normal for the spark to drift in one direction or is something off?
I recalibrated twice. It was still giving me crap.As glen said, recalibrate imu and go into the middle of a field where there are no signs of interference and recalibrate compass, fly to a hover and wait, checking on number of satellites etc
The best is usually to retrieve the .DAT flight record of the Spark as explained HERE. Then you can upload them to something like dropbox and post a link here.Is it normal for the spark to drift in one direction or is something off? It drifted up & down as well. Is there anything I need to do or it that just interference from the city buildings & radio waves?
You flying with the remote and phone or phone only?
Buildings. Cars. I was in a parking lot.what is in the immediate surrounding area?
Then it can be checked more in details. There is limited space for these flight records in the Spark, older are deleted to have space for new, so retrieval should be done as early as possible.
You can also do it yourself from the DAT file and plot flight parameters using the CsvView tools available HERE.
This way we could better help you by checking what where RC stick positions and Spark behavior.
From your initial description and this I would speculate there was a gpsHealth issue. Either the .txt or the .DAT will suffice. But the .DAT is preferable since it will allow us to see data before the flight started.Buildings. Cars. I was in a parking lot.
I tried downloading the data from the Spark but it would not transfer over or pull up for that matter.From your initial description and this I would speculate there was a gpsHealth issue. Either the .txt or the .DAT will suffice. But the .DAT is preferable since it will allow us to see data before the flight started.
I'm sure the compass is calibrated properly. It's extremely unlikely that a calibration can be flawed because of external magnetic anomalies. The Spark would have rejected the calibration had that been a problem. I.e., you would have gotten the "interfence, move to another location" message. And, you calibrated twice without any problems? In addition, there isn't anything in your description that suggests a compass calibration problem
How to retrieve the .DAT flight record of the Spark is explained HERE.I tried downloading the data from the Spark but it would not transfer over or pull up for that matter.
There is a limited space in the Spark for these flight record so the oldest one are deleted and replaced with new one.
Normally if you see your flight (time and date) you should be able to retrieve it. Sometimes it can be corrupted and it cannot be retrieved, so best is to retrieve it as soon as possible after a "strange" flight.
You mean too late, no more flight record ?I did exactly that & nothing.
