OTG cable issue.
IPedro
When I used CE, the OTG worked fine everytime. But when I switched to FCC, it only worked sometimes. I already tried many different orders, but nothing. What should I do? (I need FCC for better range)
We use cable to connect our device to controller. Using it, we can turn off WiFi on our device, so we can have less interference.
Connection between controller and spark, is something else.
That's the reason we try to fly in FCC mode, because this connection is stronger in FCC.
If everything is ok using WiFi instead of cable, I think you should try another go4 version, or another otg cable.
Don't forget to set your device in airplane mode, when you fly using cable.
There are a few solutions to cable issues I've seen
1. trying different OTG cable -- shorter cable with heavier gauge most reliable
2 the order in which the cable is connected can make a difference
3. orientation of cable can be reversed
Very important to turn off smart watch too. This is a very common source of interference for those who wear them.
Dmizzoni
