Range test comparison OTG vs Wifi Android vs IOS
jech
I made another range comparison 4.2.6 android wifi vs 4.2.6 IOS OTG vs 4.1.1 android OTG
Thanks for your share
just a question :
in A configuration you have a 2.4ghz connection with 4.2.6 version on Android...
I can configure only 5.8ghz on my installation.
Why ?
Probably because you're in Europe and your phone can only use 2.4gz to the RC forcing 5.8 between the RC and the Spark.
As for the comparison, I assume it's in CE mode ? Just switch to FCC with DJI Mod v2 and use 5.8 for excellent range (about 2km) even without OTG. OTG only avoids having the flashing "weak signal" red warning. Oh and next time do it in sports mode !!!
I'm already using the DJ Mod v2 app an previous used the fake GPS method to force FCC but in my area
I've reched no more of 800mt in 5.8
Now will trying with OTG and 2.4
seem a bit more stable but need more fly to test
There's something wrong with your setup, the range you're getting is 2.4Ghz CE. You should hit 1.5km+ easily, have you checked, that you only have 11 2.4Ghz channels, Bluetooth disabled ?
ayitsomar
