Registration Labels
Jake Nunnelee
I have tried searching to forums but can't come up with anything. Does anyone on here create labels to put on the Spark?
I sell small FAA registration stickers that will fit on the back side of the Spark battery compartment (on the empty area behind the bottom sensors). You can find them here.
Reactions: Jake Nunnelee
I believe I've found an actual decal maker that makes 1/8" backless decals and I'm working with them now. They are small enough to fit on the angled part of the cover or other places as well. Stay tuned!
I have a Casio labeler and have made Registration, name, phone number, reward if found, battery I’d numbers. Black ink on white half inch tape. For ten bucks USD including first class US postage I will make up to seven labels as you require. I always have reward if found on my controller, Spark and hardcase. The Casio label tape has strong adhesive and is weatherproof. Other colors of tape and ink available but I’d have to procure them. PM me for photos or to get your custom labels made. Really good to number batteries so you can know you’re rotating use and charge.
Either way, strongly recommend labeling all your gear by whatever means even if it’s on tape.
Reactions: MannyCAM2001
bornzero2none
