Smooth Panning?
You can also try the DJI Assistant 2 crack with V 1.1.2
This will allow you to slow the YAW rate from 90°/s to 30°/s
Then in Tripod Mode, it is even slower:
If you do not feel comfortable with the download, pm me for the file.
Question.... is it possible to edit only Tripod mode's Expo settings and leave normal modes alone?
I do have that tool, does that mod or crack as he called it still apply to the Mac version of the assistant?
I've gotten a little better at some moves, though I am still hacking out the occasional nudge of the stick from some of my videos. I may post a short one soon, get some feedback.. thanks
I believe it does, the aircraft is computer OS agnostic... should work fine. I am probably going to attempt something over the winter...
It is possible to edit expo settings for any mode. But usually people like to keep the P-mode settings at factory default and do all experiments in either Tripod mode or Sports mode. In one of the videos I saw, the Sports mode switch was set to Atti mode to practice flying in that mode.
JeroldLabe
