Spark controller not charging
/orthas
Hi all
I have received a 2nd hand spark controller.
The issue I am having is that when I plug it in the white LED's flash a few times and the go out. It won't turn on and when I hold the power button for 9 seconds as recommend on another post the first white LED will flash dimly on the odd occasion.
Is the the battery or maybe the charge port?
Have had a look around the forums and cannot see this issue with other users
Any help or advice would be greatly apprecieated
Thanks
Reactions: Flycombo
Hi all
Thanks
Hello from the Hoosier Heartland /orthas.
I would suspect that the battery in the remote has failed.
When you plugged in the cable to charge, it looks like it wants to charge but the battery says NO.
Replacement batteries are available for the remote, but may be a pain to install due to the tear down of the remote.
The USB connection on my remote has been compromised and I can no longer fly with an OTG cable so I'm flying via Wifi, which is the way the Spark was designed.
I can hold the cable just right when charging the remote.
Yes, probably the battery. Look for a few tear down videos and see if it is something you want to do yourself.
Hi all
Thanks
Hi i sell new dji spark controller cacing .they have a usb port.a button board. Batterie compartment. All new £20 .plus postage.sold a lot its usually the usb port that goes not hard to fix .thanks
What exactly is the type of charging/otg connector on the GL100A controller? I can not make a proper connection!
THX
I'm also having a problem with my controller. Have you sold many on this forum? I see you only have 1 post and joined back in February so I was wondering if you have any luck selling to all the users here?
Thanks for the reply.
