Hello
My Spark is cursed Bought it water damaged, fixed, flown for a few days. Crashed due to one motor failing. I fixed it again (frame and gimbal replacement). It was working for one flight and suddenly stopped syncing with the controller. It also doesn't show up on the PC at all. It's weird because LEDs are flashing yellow as if it wanted to connect. It charges the battery via micro USB tho... It also doesn't beep when holding the battery button. Not sure what is happening.
Does anyone have power measurements so I could check my core board if perhaps there is a power issue somewhere? There are no visible issues I could see under the microscope. All fuses seem to be okay.
Best regards,
Maciej
Best regards,
Maciej
