Hi all,
so I bought my spark combo back in June 2017. Used it like twice, put it away…
fast forward to last week and the 2 batteries don’t work… they won’t charge. I read about how the batteries had to be balanced every 6 months… it has the 1 solid light and the next light blinks and they all flash together.
i have the oem charging board as well but I also tried charging while plugged into the spark and it still won’t charge.
my controller… same thing. I press power button and the first light is solid then the next light blinks, both blink together and then it stops.
Doesn’t charge no matter what power adapter, even iphone charging 12w adapter does nothing.
so I succumbed to buying a new spark battery, it just showed up earlier today and charged it up.
i get home from work, eager to finally connect this **** this (I then learned DJI no longer supports nor makes the spark…)
the spark doesn’t generate wifi!
I tried to use the QR code on the controller, on the storage foam box, even on the inside of the drone where the battery slides in.
“cannot connect” is all I get, I check my phones wifi, the spark wifi is not listed but the drone >IS< powered on. It started up line normal and I hear the air flowing lights on the drone are on and flashing.
so… what do?
did I just get screwed? Should I just hurl this junk into the Sun
I’m never.ever.ever.ever.ever buying any DJI junk ever again.
so… what do?
