The Map....with a flight path trail
Mr Dave NJ
Northwest New Jersey
I was just watching a tutorial about the flight simulator. I noticed that in addition to the bottom left circular radar viewer on lower left, ...there was a map on lower right corner of screen leaving a path line as when we playback an actual flight we had just taken. Am I to understand that this map should show up when I am flying the Spark in real time and leaving a visible path for me to follow back? If so I am not seeing it. I use the remote controller with a Iphone 6.I connect with Wi Fi not a cable. If so where is the setting to turn it on? Thanks for any feedback......
Your screen is probably too small to show both at the same time.
I see them both on my mini4.
I think if you tap the corner of the map screen it will change to a different screen.
Pbzhch
