Plug the cable into your iPad, power on the Spark and remote controller, and wait until the light turns green on the remote controller before connecting the cable to it.In what order should I turn stuff on
Yes.will the connection be automatic
You'll be able to control the Spark with the remote controller.how will I know it's working?
Thank youPlug the cable into your iPad, power on the Spark and remote controller, and wait until the light turns green on the remote controller before connecting the cable to it.
Yes.
No. What kind of cable are you using?Do I need to have wifi turned on as well?
Got a link to the OTG cable/adapter?One of them is meant to be otg
UGREEN Micro USB 2.0 OTG Cable, On The Go Adapter, Male Micro USB to Female USB for LG G4,Samusung S6 Edge S4 S3 Android Smart Phones Tablets with OTG https://www.amazon.co.uk/dp/B00LN3LQKQ/ref=cm_sw_r_cp_apip_tLdt62oKCtJu2Got a link to the OTG cable/adapter?
Zeskit Lightning to USB Cable Pro for Headphones Amplifier / DAC - MFi Certified, Charging and Syncing for iPhone iPod iPad (10cm / 4 inches, Right An https://www.amazon.co.uk/dp/B00VRJZ2CY/ref=cm_sw_r_cp_apip_jlbwbDHCIneqRUGREEN Micro USB 2.0 OTG Cable, On The Go Adapter, Male Micro USB to Female USB for LG G4,Samusung S6 Edge S4 S3 Android Smart Phones Tablets with OTG https://www.amazon.co.uk/dp/B00LN3LQKQ/ref=cm_sw_r_cp_apip_tLdt62oKCtJu2
YepThose cables should be fine together. Did you wait until the remote controller light turned green before connecting the OTG cable?
Just saying thanks for this list.Steve, this is the checklist I created for myself:
* Power up Spark
* Plug OTG cable into Controller
* Open antennas
* Power up RC Controller and wait for connection to Spark (Controller green light)
* Plug OTG cable into Controller and lightning cable into iPhone (ignore not supported accessory message).
* Launch DJI Go 4 application
* Wait for connection message
* Select Go Fly
Don
Did you get on the iPad the message "not supported accessory" ? On mine when I don't get it, I don't have the connection and need to unplug/plug the RC connector.
No, light on rc just goes red and app says disconnectedDid you get on the iPad the message "not supported accessory" ? On mine when I don't get it, I don't have the connection and need to unplug/plug the RC connector.
You said the remote controller light turns green above. It sounds like you're now saying it never turns green. Can you clear that up for us?No, light on rc just goes red and app says disconnected
