What to use - Litchi Airmap DJI Go
I use DJI Go4 most of the time when VLOS is good for me. I like Litchi as well and use it to film on longer flights when I know where I want to go -especially if I can’t exactly see well enough to be smooth be about it Plus if you lose contact with spark using Litchi it will finish the flight and return. I have gone distances with Litchi I would never try on GO 4.
Reactions: charliespark
I usually use DJI GO since it does everything I need. Some people use other apps because they either run better on their mobile device or contain features not available in DJI GO.
I have seen such conflicting advice! I have all three Apps - which one do you use as your main flight controller?
I use both depending on what I want to do. In GO4 it's easier to shoot a pano because with Litchi you have to first set up your rows and columns to shoot. Also in GO4 I find it easier to adjust camera settings. I get better range with Litchi. I think you really need both to get the most out of your Spark
Heck
