Are you using a RC ? If not, it is limited to 100 meters distance.Does anyone think this is right? Keep in mind this is the third time i have contacted them and was same thing each time
Using rc and device with dji go 4 all firmware updated beginner mode offAre you using a RC ? If not, it is limited to 100 meters distance.
Are you using a RC only (no GO4 app connected), then it is also distance limited.
Beginner mode set ?
A distance limit set in the app ?
Everything you suggested has been done multiple times [emoji20]Wow what kind of support answer is that?? I think you get more suggestions on this thread! Seeing that chat really is disappointing from DJI.
Anyway, I would suggest resetting everything and start from there. So reset spark connection (push power button 9 sec) and reconnect step by step.
Maybe something is wrong in the installs and/or setup.
And I think everyone has mentioned this:
-disable all bluetooth from watches, phones, wife's phones, friends' phones, or whoever nearby.
-check maximum distance setting in the app
-check beginner mode
-try in another location
If all fails, I would return it. I think the drone or the rc is faulty.
Sorry about the poor response, it has been reported.
Please do as lancelot suggested.. I would also like to see how you have the antennas oriented as well. Can you post a picture of how you usually fly with them?
