- Join
- Dec 21, 2018
- Messages
- 12
- Age
- 62
I"ve read about these but don't see them in ActiveTrack. How do I get Spark to follow me in FRONT of me (flying backwards)? ONLY from the side? Thanks in advance!
Hover the drone in the the orientation, height and distance relative to the subject as you desire. Switch to Active Track mode. Use your finger to trace around subject. Green box will appear and now subject is locked.
It is confusing because the pop up instruction about drawing the box only appears the very first time you engage Active Track. Not very intuitive
Once you have entered Active Track mode, you will see an icon of a man on the left side of the screen. By default, the man will be in standing position. This is Trace Mode, which means the drone will trace the path of the selected object and follow, usually from behind. Tap on that icon again and you will switch to Profile Mode (the icon turns into a running man) - the drone will now maintain the direction it was initially facing and follow the object you select. Point to note in Profile Mode is that the drone maintains the direction it was initially facing in absolute terms. For example: If the drone was facing you straight, it will move backward when you walk or run forward. If it was facing you sideways, it will move either move right or left depending on which direction you start walking or running. If you want to orient the drone in some other direction, you have to use the RC.I understand and have successfully traced a box and hit GO; what I don’t understand is how to make it follow me in front of me or off to the side- “profile” mode
Thanks for the info, but we must know that using third party apps, voids warranty and Care Refresh insurance.Another alternative to DJI GO4 is AutoPilot (iOS only). I have used GO, Litchi and AutoPilot for tracking. From my experience, I have found AutoPilot to be the most reliable. Both GO and Litchi often loose track especially in cluttered areas (lots of trees or other objects).
Just today I was out snowmobiling on a local lake and used AutoPilot to follow me. It has an option to ‘Use Device Heading’ so I just point my controller where I want the AC to follow me from and engage the mission. It worked like a charm and if I want, I can change the heading on the fly. I used my Phantom 3 Standard instead of my Spark because it has a longer lasting battery.
The only drawback to AutoPilot is it uses a non-Standard interface and has so many options/customizations that it has a steeper learning curve.
Chris
No it doesn’t.Thanks for the info, but we must know that using third party apps, voids warranty and Care Refresh insurance.
But why endorse a 3rd party app when the official app itself can do most of things we want. A fellow forum member has very nicely demonstrated the capabilities of Active Track with DJI Go4 app. Moreover, the question asked was about how to switch between Trace Mode and Profile Mode in Active Track of Go4. Having seen how DJI Support responds to users' issues, I don't think it is advisable to use a 3rd party app within warranty period.No it doesn’t.
For a warranty issue - only if the 3rd party app is determined to cause the crash.
Fair point. But I still wouldn't recommend a 3rd party app to a beginner as we can't tell for sure how DJI will respond to a situation which doesn't go exactly as planned.My point above in my rI use DJI GO, Litchi, and AutoPilot depending on what I am doing. For tracking, I prefer AutoPilot because I have complete control over how I want to track. If I want to do a quick track in a wide open space, that I haven’t preplanned then I might use GO’s Active Track.
You're right, use of third party apps, doesn't void warranty generally, but in a software issue (every software issue), DJI will not cover the crash or fly away.No it doesn’t.
For Care Refresh - warranty is extended and accidental damage is covered as well (user error).
I have never read a post on this or the Phantom forum where flight software was the cause of the crash. It is usually user error.
Chris
DJI forum is full of reports, about DJI refusing to cover flights made with third party software.
Also, most third party apps produce limited flight logs, without detailed hardware telemetry, and this is bad when a hardware issue occurs.
I use Litchi sometimes with my Mavics, but i know that it will be difficult to deal with DJI, if there's a malfunction (software or hardware).
Chris
Yes, AutoPilot works with Spark.Is Autopilot compatible with a Spark? Other dji drones listed not the spark
