You may have to unscrew one side of the grip pads on each arm to fit a case. Unless it’s REALLY slim
Guess I’m going shopping tomorrow...
I use an ipad mini 4 ....
I too use a dedicated iPad Air 2 with OTG. Just luv the big screen view.I use a dedicated iPad Air 2 for all my drones, it is a little overkill for the spark. I occasionally use my Pixel XL with the Spark though.
If yourI use a Samsung Tab, about $149, and it works just fine. I don't use this tablet for anything else.
Firestat in Ohio
I use a an Acer Iconoa One 10 I got at Best Buy. They are available on ebay for $99.I've seen a Youtuber suggest getting a dedicated device to use when flying the spark. I currently use my daily Pixel XL and it is always a hassle to turn off mobile data then connect via WIFI to the RC. Also, the cache stores takes up tons of room. Wondering if anyone else uses a dedicated device. Considering buying something cheap (Under $100) should I go Android or iOS (ipod touch?)
Hello. So far I'm an Android person. I use either an older Samsung Galaxy S5 or Samsung Galaxy Tab S 8.4. I have no experience with Apple products.
I have heard that Apple products perform better with the Spark (do they) – maybe it's time to give one a try.
I've seen a couple people mention they love their iPad mini 4's and it fits in the Controller between the arms.
What about an iPad mini 3. I've seen these for sale used on Amazon for about $180.
The 3 is a tiny bit smaller and thicker than the 4 and has an A7 processor versus an A8. I would go for 16 GB Wi-Fi only.
Can anybody with Apple experience comment on using an Apple mini 3?
I use an ipad mini4 128g as well. I bought it for the Spark exclusively. Amazon purchase. I generally use the ipad 4 when the flight requires better detail, nothing worse than trying to make out an object on a small device. So of course depending on the subject matter. But for messing around doing low level flying, where line of sight works best, due to my proximity to the Spark. I use an ipod touch 6. Something light, compact and easier to attach a sunhood. This I also bought for my Spark. ....I know, I spoil her rotten.
Hi there, new to Spark and the forum.
About using a bigger screen, I use Apple products but my IPad mini 1 cannot be updated to use Dji Go app, does anyone know which version I need to use it? Planning to buy a Second hand one to use it as dedicated device for the Spark.
Also, with the mini you can kind of fit it on portrait mode, does any one use it in landscape without the adapter to rise it over the controls?
Thanks!
Franc
Thanks!
Franc
Agreed! It’s already a tight fit and leaves your thumbs at an uncomfortable awkward angle. I chose the Skyreat tablet holder. This elevates it off the controller leaving your hands free below it. I ended up mounting it on a low to the ground beach chair, on one of the wooden arms. This setup is great for sitting in the shade. I truly believe the more comfortable you are the better your results when flying. It also leaves my controller with nothing attached to it, unless I’m using the parabolic range extenders. Also im buying a second Skyreat tablet holder to have when sitting is not practical.You may have to unscrew one side of the grip pads on each arm to fit a case. Unless it’s REALLY slim
I stopped fighting with the hand controls and got a mount. Went through 3 of them and this one is the BEST by far. It fully collapses and fits inside my case. It's $19 on Amazon.Agreed! It’s already a tight fit and leaves your thumbs at an uncomfortable awkward angle. I chose the Skyreat tablet holder. This elevates it off the controller leaving your hands free below it. I ended up mounting it on a low to the ground beach chair, on one of the wooden arms. This setup is great for sitting in the shade. I truly believe the more comfortable you are the better your results when flying. It also leaves my controller with nothing attached to it, unless I’m using the parabolic range extenders. Also im buying a second Skyreat tablet holder to have when sitting is not practical.
Yes, its exactly the same construction as the Skyreat with the same collapsible feature but $5.00 cheaper. Very happy with mine aswell.I stopped fighting with the hand controls and got a mount. Went through 3 of them and this one is the BEST by far. It fully collapses and fits inside my case. It's $19 on Amazon.
DJI Mavic Air / Mavic Pro Tablet Holder -Lightweight Aluminum Alloy Foldable Bracket Mount Extender for DJI Mavic Air/ Mavic Platinum/ DJI Spark, Mavic Pro Remote Controller with Lanyard https://www.amazon.com/dp/B071GV74L7/ref=cm_sw_r_cp_apa_uueMAbBCF3FWJ
