Can Active Track make it track me as it ascends?
Foggy_ Harbor
Hi there, new here. I'm curious to know if when using the Active Track feature you can make the drone track you and ascend at the same time without doing it manually? Like if it starts say at 4 feet altitude when i set it to active track, can it be set to ascend on its own while I walk away or something, or is that something I would need to do with the remote or app? Hopefully you understand what I mean. TIA.
I am pretty sure it will only track from the height it is when you tell it to start. You can change the height with remote while it is following. It will not rise otherwise.
In Litchi you can set waypoints to increase in height from A to B so there may be a work around. If you set the camera on your path and set speed the same as your approximate speed between A and B. Maybe. Never thought about it.
Reactions: Foggy_ Harbor
LynI816428
