I change chanel from 5.8ghz to 2.4ghz.
ok,i fly with my android fine.
Now i want to go back to 5.8ghz to fly with the remote controler and try usb (controler to mobile device).
how i switch back to 5.8?
If I get it right, you try to use an OTG cable connection between RC and phone. You cannot control band with the cable. You need first to connect with wifi, set the band, disable wifi and the connect the cable.
forget the cable.
i try to connect mobile with rc and i see in the screen only 2.4ghz.no way th change to 5.8ghz.
so i can not fly the spark with the rc.
in the up left corner at dji go 4 always says disconnected
