i try before the tss mod up and one time crash....the original app never crash...i have samsung s8..with this app may have problem with crash??
Give it a test, no guarantees, but someone with an S8 tested and reported it working
Testing here with Samsung Tab S2, so far so good! Except for the Map issue. Unfortunately it's too dark here now to continue to fly and test.
Thank you for this, I'm having fun experimenting with this!
Reactions: dubt
Ok, 2.0 update is sorted, along with a LITE version of the app.
Each has specific feature sets:
DJI GO 4 MOD 2.0
  • Auto enable screen rotation
  • Red Status and Nav Bars
DJI GO 4 MOD LITE
  • Offline Maps
  • Here Maps
Both Apps Feature:
  • OTG Support
  • Sphere Pano Support
  • DJI GO 4 Ver. 4.1.15
The Change Log for each being:
DJI GO 4 MOD 2.0
  • New Custom Icon
DJI GO 4 MOD LITE
  • Initial Release
Get your download on!
DJI GO 4 MOD 2.0 - Download
DJI GO 4 MOD LITE - Download
Work fine on 1.1.1 version using OTG. Google Map is loading. Tested indoor flying. I guess it was connected to my Home WiFi that's why the Google Map is loading. My device tested are Nexus 6 and Mate 9. I preferred the Google Maps and the new Beta Maps on 4.1.22. DJI already claimed that the Here Map is not stable that's why the offline Maps are no longer available on 4.1.18 onward.
Work fine on 1.1.1 version using OTA. Google Map is loading. Tested indoor flying. I guess it was connected to my Home WiFi that's why the Google Map is loading. My device tested are Nexus 6 and Mate 9. I preferred the Google Maps and the new Beta Maps on 4.1.22. DJI already claimed that the Here Map is not stable that's why the offline Maps are no longer available on 4.1.18 onward.
2.0 is basically a new repatched apk that I can verify is safe because I patched it on my own PC. Highly recommended to update as it should have the same features as 1.1.1.
What versions of Android are your Nexus 6 and mate 9 running?
Glad you like it!
Reactions: Edikfly
Glad you like it!
Nexus 6 Oreo 8.1.0 and Mate 9 Oreo 8.0.
Reactions: Edikfly and dubt
This is super awesome. Thank you for all the time and effort in gathering and collecting all information regarding this mod. OTG is strong and works fine on my Samsung S7 running Android 7. 3 batteries in so far. All intelligent flight mode works too. Haven't tried way points yet. Huge learning curve with all these newly enabled modes!
Reactions: dubt and Edikfly
No luck for me.
Crack at start, complaining about a database it can't create or access to.
Tried v1.1.1 and v2 with same results.
Archos Neon 70c running Android 6.
Reactions: olivgr1 and dubt
I believe the issue is the CPU in your device. Android isn't that picky, but sometimes it's is a different enough device, it will refuse to run.
What processor is in it? Mediatek or snapdragon?
If it's neither, that's not a good sign.
If you can't even find a processor name, that's not good sign either.
Reactions: Edikfly
Get some incredible shots in Panama!
Do you mind posting the Android version your Nexus 7 is running? Have you left it stock, or flashed a custom ROM?
My nexus 7 is totally stock running Nugget. and fits perfectly in controller after after slight modification. Keep up the good work, Much thanx. will post some shots soon.
Reactions: dubt
Galaxy Tab S3 here. Yesterday I did about 4 hours of flying with the original modded apk from the other post. That one worked flawlessly all afternoon using WiFi. No disconnects, no glitches.
Just did a flight with this mod and the experience was the same. The only issue I had was that Google Maps would not load, just showed blank. I do not have an active data connection when using the Tab S3 as it is strictly a WiFi unit. I do, however, have offline maps downloaded in the Google Maps app and was hoping they would work with your API mod. Seems to only want to work with a data connection.
Same result with nexus 7
No luck for me.
I had a similar issue before. Full wipe fixed it.
arshadkhan
