DJI Go 4 update - 4.2.4 update on both IOS and Android
Thank you, so turn WIFI off pre flight, should i also put phone into aeroplane mode to prevent incoming calls etc or is this not required?
If you turn on airplane mode you disable all tx functions, should result in a better connection with the spark.
But, if you don't enter airplane , you can transmit live video, may not be able to fly as far though
Reactions: LiamB
That's a good idea, but it's not required.
Sorry for all the questions but its crossed my mind if this is done will the spark still plot its history on a map post flight incase something goes wrong and i need to track it?
Yes.
Reactions: LiamB
Just upgraded to 4.2.4 to check and see if OTG and Offfline Map has been fixed. Sadly this is not the case. It's back to 4.1.15.
Is "mapbox" a new moving map the GO 4 app is moving to?
Reactions: Rodrigo Herrera
It appears that the newly released IOS version of DJI Go 4 is working properly with the OTG. I have not seen any weak signal warnings, battery and video transmission data is showing up. It seems to be working!
DJI GO 4 ver. 4.2.4
So far I do not see any new release of the app for Android.
Reactions: LiamB
I just posted the same thing in the software and firmware section of the forum. It looks like this new version in IOS 4.2.4 is working for me with OTG.
I also use android, but I have not tried it yet
Need to Know If you guys think I should give OTG a go with the new update and If ND filters are worth It..
Cheers Craig
Oh, I am kinda new here. Didn’t realize shearing my experiences. Was illegal.
Check telemetry data "H", "D", "V", Satellite, and battery level are all being reported as "N/A".
I'm running 4.2.4 from Android 7.0.
Are you using Android or IOS. I only got the up date for IOS.
Does it completely work or just mostly work like it used to? By that I mean can you assign the buttons and it remembers them, etc.? I'm betting on mostly works, I would think there'd have to be stuff added in the firmware.
Yep, under "settings" it shows "DJI GO 4 v4.2.4(509-googlePlay)".
From Play Store:
What's New
Added compatibility and features for the Mavic Air:
- Added APAS (Advanced Pilot Assistance Systems).
- Added ActiveTrack with multiple subjects identification.
- Added new Boomerang and Asteroid QuickShots (with v01.00.0100 firmware).
- Upgraded Gesture mode to SmartCapture mode (with v01.00.0100 firmware).
- Enhanced Pano shooting with improved image stitching and
effects (with v01.00.0100
firmware).
- Supported the Mavic Air’s internal storage.
- Fixed bugs and updated certain features.
Version. Updated on
4.2.4. Jan 23, 2018
Reactions: leatherneck6017
bashirul
