DJI Go 4 update - 4.2.4 update on both IOS and Android
Just tried flying this morning and appears that OTG weak transmission is back?
Worked when back on Wi-fi.
IOS
V4.2.4.
Turn drone on
Turn RC on
Wait for green light
Plug cable in
Turn app on
Is this correct procedure ?
V4.2.4.
Turn drone on
Turn RC on
Plug cable in
Turn app on
Nope. The last thing you should do is plug the cable in. I do it this way and it works perfectly for me on my iPhone 7+
RC on
Spark On
Open app
Plug cable in
You’ll then get a message about accessory not being supported. Should be fine from there.
Reactions: craig Dixon
I have the same equipment. Cable worked once but couldn't get it to work again. New mini 4. Only had a few minutes to play with it. Question: is there a specific sequence of power on, connection that you use?
See my post above.
This is how it's been working for me.
In Wi-FI settings turn off "Auto-Join" for the Spark RC or it will keep trying to automatically reconnect
Turn Bluetooth Off
Connect OTG end to i-pad or i-phone
RC on
AC on
Open DJI GO 4 App
Connect OTG cable end to RC
Dismiss "This Accessory may not be supported" message
"Trust this Computer" select Trust (enter your password if required)
Oddly with the i-phone 8, if I connect the OTG cable to the RC end first and then connect the I-phone last. It doesn't want to recognize the connection.
Turn Bluetooth Off
RC on
AC on
Open DJI GO 4 App
Thank you very much....
Turn Bluetooth Off
RC on
AC on
Open DJI GO 4 App
Doesn’t work for me that way. If I don’t connect otg last it just doesn’t see it. You’d think it’d be the same for everyone.
Reactions: Donny
Anybody got it working with Android yet? Tried 4.2.4 from playstore but don't shows the data with otg cable.
Really:mad: :mad: No OTG support for Android.
I think the DJI developers should visit Europe and try to fly the Spark with wifi only.
I can fly my toy drone higher and farther away, than the Spark.
fulavio
